repairman2
I have a washer/dryer stack that fills with water but will not agitate or spin.I can hear the motor hum. I removed the pump , changed the timer and got the same results. Can someone please help me with a repair manual and help with what the problem may be.  Peace  :(
  • Replies 7
  • kdog
  • repairman2
  • RegUS_PatOff
  • certified tech group 51
While in spin, will it drain if water is in the tub??  It may be your coupler is broken......
repairman2
No it won't drain
When you look at the shaft with the pump removed, is it spinning?
repairman2
No, not spinning
Sounds like a motor issue, or related wiring
you could remove the Pump and the Motor and while holding the Motor with your foot,
try the Washer again ...
With power removed, can you turn the Motor Shaft by hand, easily, smoothly ?
