need service manual for older whirpool dryer. Model # tag missing
vivalamigra
I have some photo bucket images of the front and the guts.  Maybe some kind soul will recognize it and hook me up with a service manual?
thanks
  • Replies 4
  • RegUS_PatOff
  • vivalamigra
  • DADoESTX
from the part number 690207 on the Timer, seems like a LE5700 series c. 1983
but uses a different Start Switch.
If you could post the part number on the Start Switch I could get closer ..
vivalamigra
Start switch is 346364.
Not LE6400XKW0 (1982 model-year) or LE5700. Older dryer. LDE series, 1976-1977, I recognize the control panel design as being such. Possibly LDE5750W2. Seems to be standard capacity, no bump-out on the rear bulkhead for super capacity. Three temps, plus autodry, so not LDE5700 which is timed-dry only. Has a thermal fuse, which seems to been added on the 2 revision, not 0 or 1.
