anyone have a service manual for this fridge? i already have the techsheet. thanks.
  • Replies 6
  • Budget Appliance Repair
  • RegUS_PatOff
  • appl.tech.29501
[user=28826]mrfixit2[/user] wrote:
no one has one?
It's made by Whirlpool, but to Kenmore's requested features/options
I can't find a completely compatible Whirlpool model.
What problem area are you having ?
thanks regus.i've tried to get into the compartment in the fridge section at the top front of it.i wanted to get at the adc . there are 2 screws at the back of it but after taking them out there is something still holding it at the top front. the samurai sent me diagram of it.it didn't show the 2 screws, but showed a screw on the front that i can't find. the fridge was displaying defrost problems and i thought the adc was bad but while doing the test on that system i found that the evaporater fan was working intermittently and then quit altogeather. i've ordered the fan already ,so problem solved. but i wanted the manual for future to see how that cover comes as this is one of my customers. samurai posted the diagram under the kitchen form, under this model # and mrfixit. thanks.
I believe you have to remove all the control knobs/sliders on the front, then the front control face/trim will snap out.  That will give you access to the two other screws that are holding the the control console assembly in place.
thank you, i'll give it a try when the part comes in. will let ya know. thanks again.
Yep, Willie's right, remove knobs and pop the it off from the top edge all the way accross.
