Frigidaire Refrigerator #FRT04L5DW0 Serial#RA62563827
jambatt
Can't find any info on this unit at any of the regular parts sites including RC. Need overload and start relays. Have had the same problem finding any info on similar Friggy models. It's a small top mount unit. Any help would be appreciated.
  • Replies 13
FRT04L5DW0
FRT04LG3DW
can you check that model number again ?  :ooo:
I hear what you are saying Reg but that's the number in the box. I hit the same wall. I checked three times before posting. Had same problem with similar unit last year. None of the part sites recognized the model. Figured you could get it out of Frigidaire if anyone could.
is this in the U.S. ?
Yessiree, thus the 23 miles offshore location. Little island of the coast of NC. I think it is a Chinese knock off marketed under US company name. Sold a Home Depot.
this could be your "complete" :headscratch: Parts List & Diagrams
Does the Compressor and Start Relay have any numbers on them ?
Thanks for the effort Reg. These things are designed to be disposable I guess since no parts are listed. Found out the overload relay was made in Spain and the run relay was made in China along with the compressor but by different companies. Had similar one last year that needed a defrost timer. They used special screws on the cover so you couldn't access it. Also made the defrost heater so you couldn't access it.  Just weren't designed to be fixed I guess.
Yea, we're keeping an eye on it. This place saw it's share of oil on the beach in WWII. Ole timers say they had to wash their feet off with kerosene after walking on the beach.
If the compressor has the standard 3 pin configuration you can put almost any relay on it.
if its the 12 cu frost free its made by either danby or LG
try model number frt125gw
or  frt125gwk
or frt124xxx
its one of those
home depot has their model number changed
and yes they are considered disposable
btw the screws on the timer box can be removed with the tips of your needle nose pliers, next time you have one try it and you will see what i mean
very few parts are available, the thermal fuse on the newer models can only be ordered by special request with a form sent out to authorized servicers  <shrug>
heater not available
they are total crap, friggy doesn't even want us to go out and look at a large serial number range of them, we are supposed to just request exchanges on any made before RA921 (think thats the date stamp)
i have to request an exchange for one of these at least once a day
btw, the defrost timer for these lists for over 80 bucks... again <shrug>
and you cant use a universal, the original is a 6 minute timer
if you read the wiring diagram you will see the timer stalls once it goes into defrost,then once the dts opens the 6 minutes counts down and cooling resumes
older versions were only defrosting the bottom half of the evaporator, the top half was turning into a solid block of ice(not frost, solid ice)
the newer versions if you peel back the aluminum tape in front of the heater you will find the styrofoam insulation has a big chunk melted away
tech support is absolutely no help on these, even they just say its junk and not worth fixing
then there are some that rain the defrost water out the front vent in the fridge roof, even if the fridge is sloped backwards
cant take it apart to see how the water gets there, and i have never taken the time to cut away the plastic on one of these that was scrapped
oh crap!!!!
i saw reg's parts list
friggy has a 2 door bar fridge?
SIGH!
gotta be danby built, only they make crap like that
Thanks guys.
Reminds me of the Magic Chef crap that Home Despot sells. Those kind of appliances belong at Target or Wal Mart.
