Whirlpool ET1MTKXKQ00 fridge freezer fan motor how-to?
slantsixdan
Whirlpool upright fridge-freezer
Model ET1MTKXKQ00
Serial EL27728780
Type CT1TFA01
Mfg Date 07-01
I'm now getting a rhythmic low-pitched "failing bearing" chirp from the fan in the freezer. Sounds like probably one chirp per motor revolution --> --> sounds like time for new fan motor. What's the R&R procedure, please? (Don't have a service manual; can one be had?)
Thanks!
Freezer fan motor kit
(The manufacturer has replaced part number 2183833 with this item, part number 4389142.)
(Manufacturer part number 4389142 is RepairClinic item number 921540.)
click on picture
this may be your service manual:
Apartment Maintenance Series-Top Mount Refrigerators
Evaporator Fan # 10
Thanks much. New fan motor's in and running quietly, as it seems.
