Maytag MAH2400AWW
jambatt
Customer said it took over four hours and several restarts to do last load. Will fill but will not start tumble cycle. Just stalls out.  Code record shows E3  last recorded. Unit in service mode will not complete quick spin mode. Tub starts out at about 50 rpm and then just stops. See no burned spots on control board. E3 says to check motor, connections, speed control, and control board. Motor checks out. Reseated connectors. Not sure where to look for speed control. Couldn't find it in parts diagram. This unit is much different from the Neptune. Could there be something else besides the control board???
E3 ?
or
3E ?
Motor OHMS out OK ?
looks like the Motor Controller is part of the Main Controller
E3 ?
or
3E ?
Motor OHMS out OK ?
:oops: My bad. 3E. Motor ohms out. Sorta figured it might be in the control board but wasn't sure. Guess I'll throw the SWAG method on it and change control board. Thanks Reg.
