lucien55 Posted June 26, 2010 Posted June 26, 2010 I too could use the link to the Sub Zero technical service manual covering the model 532. Also, in one of the discussions diagnosing a problem with a 532 you differentiate between early, middle and late serial numbers as they applied to when the compressor and refrigerator fans should run. My unit is serial number 978926 and I'm wondering which group I fall in to.This site has been tremendously helpful - thanks in advance.
RegUS_PatOff Posted June 27, 2010 Posted June 27, 2010 [user=68108]lucien55[/user] wrote: ... a 532 you differentiate between early, middle and late serial numbers as they applied to when the compressor and refrigerator fans should run...it's more than that on some 500 series ...your Condenser Fan runs continuously (a Relay can be added)yours would be:WIRING DIAGRAM & SCHEMATIC - 532Madison/Phoenix Production From Serial #M815564/P725022 to #M/P1004775, Except Between #M964770 to #M965069, and Except Between #M990700 to #M990999service manual link PM'd
lucien55 Posted June 28, 2010 Author Posted June 28, 2010 Great, thanks !Also, after reviewing many, many other posts here, I opened a new topic today for help with my refrigerator. The subject was Sub Zero 532 but it doesn't come up when I search. I assume there is a waiting time before posts are reviewed and added or did I just screw up (not the first time!), thanks again.
RegUS_PatOff Posted June 28, 2010 Posted June 28, 2010 It's in the Kitchen Appliance Repair forum ...
