Need manual for this commercial washer
  • Replies 5
  • gnrook
  • RegUS_PatOff
  • appl.tech.29501
Particular problem we can help ya with ?
The washer is set to a large load and fills to the large to wash and when it goes to fill for the rinse it only fills half way. I was wondering if on a commercial washer specifically this model were they trying to conserve water by only filling to that amount on the rinse.
This washer has 2 pressure switches in it.
Greg
did you motice the NOTE at the bottom of the Wiring Didgram ?
FEATURE CONNECTOR 2
CONNECTION LOCATION
NOT USED ON ALL MODELS
FEATURE CONNECTOR 2 TO BE USED ONLY ON UNITS SOLD OUTSIDE OF UNITED STATES:  :whistling:
FOR DEEP FILL RINSE WHEN LARGE WASH CYCLE IS SELECTED,
FEATURE CONNECTOR TO BE PLUGGED INTO V-Y WIRE FROM TIMER SWITCH IOA
CAM2762TQ0 Parts List
CAM2762TQ0 Installation
Thanks for the help [user=3641]RegUS_PatOff[/user]
I just seen that there before you posted your reply. I am from Canada so the connector 2 should be on.
I did not have a wiring diagram for the machine to see that.
I apprciate your help
Greg
