Kenmore refrigerator
fixit guy
Model number 106.53662300.  Unit is getting too cold in freezer side.  Trying to look up thermistor but only find one.  Should there be two?  Service manual anyone?  Did dianostic test and all passed.  HELP
Fixit Guy.........
  • Replies 7
Thanks [user=3641]RegUS_PatOff[/user].  Do you have a clue where they are located.  My parts supplier could not find but one located in the damper.
Thanks again...
hhmm  ... I can't seem to find the Freezer Thermistor, either ..
(I'll keep looking)
maybe that model doen't have one ..
does the FC Thermsitor Test pass ?
Yes.  The freezer is getting so cold that the drain is freezing after two days and frost is all over the ice maker.  I am thinking control board and need to replace thermistor also. I shot the ice and it was -28. I am running out of options.
hhmm...
looking at the Controller for that model doesn't match the Connector/Pins, ect of the Tech Sheets.
I wonder if the refrigerator thermistor is located on the control board  :headscratch::headscratch:
according to the diagram, both thermisters have harnesses from the control {or-t/wh, bu/wh-or), you could follow the wires, I worked on a K/A sxs last week that had one thermister snapped into the damper housing and the other passes through the housing and dangles in the air channel in the freezer side
