a few basic questions
appl.tech.29501
Is there an industrial type covering that is made for the short run of suction line from the outside unit to the house or is there only foam?
Which insulation do you think is better the old fiberglass roll or pellets?
What you are looking for is a black colored closed cell type foam insulation that is uv resistant. Rubbatex and Armaflex are two brand names often seen. This is not the same stuff as the grey lightweight junk they sell at home improvement stores.
As far as home insulation goes, I am not a big fan of the neverending mess that comes with blown in insulation, But it is the cheapest way to go(not best r- value wise, just cheapest).
Fiberglass is better , but very expensive if you are going to use the correct thickness (r-value)for an attic.
If you are serious about doing something that will truely improve things , then Spray foam is the way to go. Most attics that I go into with spray foam are usually no hotter in the attic than it is outside. That is pretty impressive considering that same attic might have been 120-140 degrees with no spry foam insulation.
Thats good to know, thank you for your input.
  • 3 weeks later...
Also the rubbertex comes in various thicknesses for various degrees of insulation.
