Anyone have a manual for this microwave or what the high voltage side specs are? I keep blowing the HV diode after about 2 minutes. Everything else seems to be OK, but oviously something is ary. Any past experience knowledge??
  • Replies 6
  • appl.tech.29501
  • BradE
  • RegUS_PatOff
I don't think we have a manual for this unit. Have you checked the capacitor for a short?
Capacitor checked OK, tried an extra one I had anyway. Same scenario.
Time to check the Transformer
  1. UNPLUG the oven.
  2. DISCHARGE ALL HIGH-VOLTAGE CAPACITORS. (Procedure)
  3. Disconnect the high-voltage lead from the transformer's high-voltage terminal (or tap).
  4. With an ohmmeter set to the lowest resistance scale, R X 1, measure the resistance from the high-voltage terminal to the transformer chassis (ground).
    1. Some early models are equipped with two or three high-voltage taps. If this is the case, perform the measurement from each tap to chassis ground.
    2. The meter should read about 55 to 70 ohms, depending on which high-voltage tap is being measured and the model being tested.
      1. A substantially higher or lower reading would indicate that the transformer is defective.
[*] Carefully disconnect the leads from the primary (input) terminals [*] Measure from one transformer primary terminal to the other for a normal reading of less than 1 ohm (i.e., .22 ohms)
  1. A substantially higher reading would indicate that the primary winding is open.
[*] Set the meter to its highest resistance scale and check from each transformer primary terminal to the transformer chassis (ground) for a normal reading of infinity (open circuit).
  1. Any measurement of resistance would indicate some degree of a short to ground
[*] Set the meter back to its lowest resistance scale. Then carefully disconnect the filament leads and measure from one filament terminal to the other for a normal resistance of less than 1 ohm. [*] Set the meter to its highest scale and measure from each filament terminal to chassis ground for a normal reading of infinity (open circuit).
  1. Any measurement that is substantially different from the normal readings would indicate a defective transformer.
Because I don't have the specs, I don't know if this is out of range or not. I am getting 134 ohms on the high voltage lead to ground. Don't know if you have access to this models specified range.
thanks
that seems high...let me do some more checking
lists JVM1440  but doesn' t show that particular schematic
others may be similar
one schematic shows the Transformer resistance values ,,
link PM'd
