Hello again guys. I need service / repair manual to tackle F70 code issue. Need to access UI to troubleshoot. Thanks in advance. Mahalo.
  • jtech1111
  • RegUS_PatOff
Unplug the blue connector on the MCU to see if it comes back on. If it does, then you need to replace the MCU. I have found in similar cases that pulling the board out of its case revealed corosion that was causing the problem.
thanks so much for much needed whizdom.
