Kenmore Dryer 417.84072300
jambatt
No heat. Continuity on elements,thermal fuse, and thermostat. New control board, still no heat. Is user interface next????? Only thing left or am I missin' something??? Touch pad with digital readout.
  • Replies 6
Drum runs ?
how's the House Circuit Breakers ?
and the voltages at the Dryer Terminal Strip ?
417.84072300
Owner Guide:
134235700en
Wiring Diagram:
1342003e_sheet_1
Installation Instructions:
42354e
Parts Manual:
5995393401
Operating Instructions:
42353e
Ditto on Regs. voltage check, also check the 2 wires that go to the heat relay on the board as well. They have a tendency to melt internally and or together sometimes.
Thanks guys. Owner decided he'd rather put his money in a new one instead of this one.
[user=24427]jambatt[/user] wrote:
... Owner decided he'd rather put his money in a new one instead of this one.
Missin' something, good possiblity!!!
Elements - check
Thermal Fuse - check (the one on the back of the cabinet behind drum, right?)
Now here's where you maybe missing something:
Thermostat - the picture on the parts manual that RegUS linked to shows a
picture of a standard cycling t-stat with bias heater that the
standard non-electronic models use but the parts list actually
list the part as a '134216500 Thermistor,control' which I would
expect to see in an electronic control model. It is in the same
place as the normal cycling t-stat would be mounted, (front of
blower housing).
If you just checked it as thermostat and saw that you had continuity but didn't really note the ohms reading it very well could be bad, out of spec, and dryer thinks it's already hot.
  • 2 weeks later...
Way to go Willie. Just as you said, continuity checked but didn't have the wiring diagram. Owner removed it. A big DIY'er. Thermistor read 2.7 ohms instead of 57. Thanks to everyone.
