Lookin for an Ole Maytag Electric Dryer manual
jmatthew
I have a Maytag electric dryer, Model TXA436AKA2, S/N E041720884 that is is making rubbing and squealing noises.  Before I start popping covers, I would like to look at the machine manual.
Does anyone know where one can be found?
EDIT: Duh, I posted this in the wrong area...
  • Replies 7
[user=56484]jmatthew[/user] wrote:
I have a Maytag electric dryer, Model TXA436AKA2 ..
TXA436AKA1   ICP Air-conditioner/heat pump (outside unit) CONDENSING UNIT
could you check that model number again ?
Wow, will do!
And, your were correct, although I wasn't.  The model number was for our air conditioner unit (I grabbed the wrong post-it note.)
Okay, let's try this number:
Maytag 747G
Model: DE407 Series 01
S/N 241867YM
We dont have a manual for that...I may have one at work, i'll check tomorrow. What kind of problem do you have?
Maytag DE407  circa 1976
Parts Diagrams
Thanks for the parts diagram and interest. The squealing is coming from the rear of the drum/blower area.  We (the MAIN END USER) and I have decided it has served us well.
Time for a new dryer.
I did look for a manual today and my boss decided to throw it away a while back for some reason. Sorry to hear your letting it go, I use to have that same dryer. You probably just need a little lubrication on the wick for the bearing.
