Tappan gas range TGF362BBBA
AmTec Services
Customer calls and says screen is blank on controller. Before I run the call, is there a spot to check voltage input. Are there any in line fuses. Cust says burners light up so I guess there is power to the stove.
Thanks!
..................AmTec:shock:
  • Replies 6
:D  Thanks Regus!!! You rock:rocker:
.....................AmTec:cool:
  • 3 weeks later...
Replaced this clock timer today. Unit back on line and custumer is ready to bake cookies this weekend. That clock timer was $238 my cost!!!:shock:
Thanks for the diagram Reg.!!!!:D
[user=66622]AmTec Services[/user] wrote:
.. Unit back on line and custumer is ready to bake cookies this weekend.
316064502
Might want to put your parts supplier in the head lock and tell him to give you a better rate.
My cost is $200
Definitely will be doing that. Trying to build up my volume
Thanks for the heads up!!!
