need help. service manual for viking model ddbb362r-ss
Im working on this frig and its leaking water at bottom ref door hinge. No idea how water is getting there and everything is riveted to boot. Any help?
Thanks Grant
  • catservices
I'm thinking the hinges are sagging letting cold air spill out onto the lower hinge, chilling it off and turning it into a metal slab dehumidifier.
I PMed you a little goodie with the hinge adjustment tutorial. It's a beeotch of a job, requires two pair of cahones.
  • 1 month later...
Its been a while but I just wanted to thank you for your input.
