Questions for the Masters
AmTec Services
Can the whirlpool modulor ice maker be tested on the bench, or does it need to be at 17 degrees for the manual harvest test to work?
What is the purpose of attaching the power wire to the bottom of the mold?
How long does the jumper need to be be at T&H to begin harvest?
This apprentice humbly awaits your wisdom!
...................AmTec:java:
  • Replies 9
Typically you would check it in the unit rather than on the bench, you would have to devise a patch cord to supply voltage to the proper pins to the I'M harness.
The thermostat doesn't have to be 17 to manually cycle the uniyt by ther T and H test ports because this by bypasses ther thermostat.
When you install the juper into the test ports (T and H) generally you don't need to leave the jumper in any longer than 10 seconds as long as the unit immediately begins to cycle. Listen for the contacts to click with rotation first begins.
do you need the IceMaker service Manual ?
That would be awesome and much appreciated!!!
Thanks to you both!
..........................AmTec
Icemaker - Ice Dispenser
there's also a few others for the LED / optics and others ..
  • 2 weeks later...
Most wiring harnesses typically include a thermal fuse which is kept in contact (or near contact) with the mold with a small stainless steel clip. If the I/M overheats for any reason it kills power to the I/M , a good thing.
Got a troubleshooting guide for the optical icemakers here...
http://fixitnow.com/wp/2010/06/29/troubleshooting-icemakers-with-the-fancy-optical-controls/
And here's a handy wiring diagram and test point listing courtesy of Master appl.tech...
http://fixitnow.com/wp/2010/09/05/whirlpool-built-modular-icemaker-wiring-diagram-and-test-points/
Did you send that to me, Reg? If so, apologies. I rectum that age-induced brain shrinkage is stating to catch up with me!
Edit: Ah, I see, I got from another topic here you posted it. Appl.tech has been sending me so many wiring diagrams that I'm starting to get confoosed!
[user=1]Samurai Appliance Repair Man[/user] wrote:
Did you send that to me, Reg? ...
I don't think I sent it to you, but I posted it in the message link (above)
