brettmat Posted September 2, 2010 Posted September 2, 2010 Hi. Would you have a service manual for a Whirlpool Front loader AEO 3561 Please?ThanksBrett
RegUS_PatOff Posted September 2, 2010 Posted September 2, 2010 I can't find much info on that model (yet) What seems to be the problem ?
brettmat Posted September 2, 2010 Author Posted September 2, 2010 Have just completed a tub repair (used a plastic welder to weld up the polypropylene), all back together but fails when the drain pump should run with a FP error?
RegUS_PatOff Posted September 2, 2010 Posted September 2, 2010 standard tests... Press Drain/Cancelis there voltage at the Drain Pump ?does the Drain Pump run ?Hoses kinked/clogged ?
