Info on truck stock
AmTec Services
I need some input for a common truck stock. It's mostly electric in my area, not to much gas.
My main supplier is Marcone.
What truck stock should I have? My goal is to finish most calls the first trip out.
I have all the common split system a/c parts as my main business is HVAC repair and replacement.
Any help would be greatly appreciated!
.........................AmTec
  • Replies 12
  • appl.tech.29501
  • AmTec Services
  • jmax6620
  • frod
cant help with AC parts but I can with Appliance parts. Do you know what the most common brands are in your area?
Any help with that stock list? Need common parts yall carry. If I can sell it I dont mind stocking it. Any help is greatly appreceated!
............................................AmTec
appl.tech  - Would you mind sending me the same stock truck list?  I have the same problem in deciding what to have in inventory.  It would be greatly apprieciated.
jmax6620
  • 3 months later...
  • 3 years later...
Just starting in the appliance repair business and need a good parts list fot the brands listed above. Could you send me the list you sent to the others. Thanks!
You should be able to contact your local parts supplier and they should be able to give you a list of the fastest moving parts. Every area is a little bit different. That's what I would do
  • 2 years later...
