 NO HEAT:X
Service Manual Request Please
Whirlpool Supreme Gas Dryer
Mod# LGR7848DQ1
  • Replies 5
  • sgilber
  • RegUS_PatOff
  • appl.tech.29501
Thank you very much!!!
I have an open Thermal fuse. I jumped it and everything fires up fine.
I cleaned and vacuumed the entire unit, and will pick up a new fuse on tuesday.
Any other ideas why this opened?
Again, thanks very much....the small investment in your site is pricless!!!
Check your vent system completely from the dryer lint filter housing all the way to the outside of the dwelling. A restricted vent is the # 1 cause for this fuse to blow.
All cleaned...NOW!!! and shortened the hose, again thank you
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
click on picture $ 4.99  sometimes on sale for $ 2.99
