IDENTIFIYING COMPRESSOR TERMINALS
Bobice
Using a good multimeter set on ohms, remove the compressor terminal cover with the unit off.
Touch one lead (of the meter) to one terminal and the other lead (of the meter) to one other terminal and record your reading . Lets call these terminals (A) and (B). The remaining terminal lets call ©
So for example A-B=7 Ohms
Now lets read A-C and record. Lets say 5 Ohms
Now lets read C-B and record. Lets say 12 Ohms
Now lets add all the A's= 12 Ohms
Now lets add all the B's=19 Ohms
Now lets add all the C's=17 Ohms
The highest reading will be the "Start" winding
The next highest reading will be the "Run" winding
The lowest reading will be the "Common" winding
Therefore B= "Start"
The next is C="Run"
The remaining terminal A= "Common"
  • Replies 10
Domo for posting these most sagacious and expeditious pearls of appliantological wisdom, Brother Bob! :dude:
Most compressors now go c-r-s...top to bottom, left to right. on residential more than 5 ohms total something is going on whether its age or wearing down... c
common to start
common to run
run to start should be equal to the above readings combined.
For most of the compressors, I start at the single one, going clockwise..... common..... run....start  ............ C.R.S.........   Can't...Remember.....Shit.........          What throws me for a moment is when   Common....Main....Phase............   is used..
Ah Yes as usual some people are never happy. :P
The ohm values given were not specific to any compressor, just used for LEARNING but alas there is always someone complaining. :shock:
Just adding to the useful info.
edited order above..
common to start
common to run
Not all compressors  follow the left to right rule.
Common to Start in the examle =7 Ohms
Common to Run in the example =5 Ohms
Common to Start in the example = 12 Ohms
Again this is an exercise using the multimeter which alot of "Technicians" as well as "Newbies"
could benefit from.
I agree. some older compressors dont use that rule. From what ive seen most all of todays compressors use it,of course there are probably those lone odd units..... techs need more trouble shooting and less parts changing.
:D :D We at least agree on the training.
Before being laid up I worked with *NATE   giving a prep course and was amazed at how many technicians were poorly schooled.
The other sad part were the "Technicians" who went to pay per learn trade schools and were clueless.
As far as compressor terminals Embraco were the first ones I came across with common on bottom,run on left and start on right.
*North American Technician Excellence.
I am nate certified. What I hate is the hrs needed to keep up the cert.
Worse is there is "No Hands On" requirement to be "Nate" cerified.:X
