masters- i need service manual for this fridge for further trouble shooting. heater looks burnt but has 21.9 ohms, board replaced that's what told to be the problem only thing left is the stat nc or no?
  • Replies 10
  • BLTH15
    5
  • RegUS_PatOff
  • appl.tech.29501
that would be 31-9071
link PM'd
reg- I can't open the link is it me or something you did?
left-click on link ...
works for me
reg-got it thanks reg i don't do fridges trying to help a friend
That unit has a "high limit" defrost thermostat (NC)
And a defrost thermistor.
Did the unit have a defrost issue?
yes- things are so much easier when you have a tech sheet. but i defrosted it manually and the fridge is still warm damper opens , fan comes on?????:shock:
and compressor?
what's the frost pattern of the Evaporator ?
picture ?
does the evaporator coil have a frost pattern? Even layer of frost over the entire coil?
