Click here to take the quiz.
      6
I need the "key dance" so I can reset the temperature on this oven.
  • benderdome
  • RegUS_PatOff
Oven Temperature Adjustment
Press the Bake key and slew the temperature up to 550 F.
Press the bake key again and hold for 3 seconds.
The Bake key must be pressed within 30 seconds of the first input.
The temperature offset is displayed and can be adjusted from -35 F to +35 F.
Use the slew keypads to adjust the temperature offset.
If any key other than the slew pads are used, the control will return to time of day display.
Hey thanks - I'll give it a try and see what happens.
Hallelujah !!! Worked perfect - Thank you
