Supco Refigerater Parts
Tuco
I was thinking on tyring to have a few Supco parts on hand . Or any parts.
Just in case a friend calls with a thawing fridge or freezer.
There are no appliance parts stores near me . All parts come in by mail.
What do you think of Supco refrigerator parts? I don't want allot of parts I may never use. "One size fits many " seems to be a good ideal. Any thoughts or suggestions?
  • Replies 7
I would only use Supco parts in two situations: 1. To get a refrigerator running again until I can get the original OEM part on hand to do a proper fix, 2. If the refrigerator is on its last leg and it doesn't really matter, just trying to keep it going for a while longer.
That good huh? For some reason I thought Supco was better then that.  Are they related to the old Gem line parts (RIP) ?
The problem isn't Supco, per se, the problem is using any generic compressor starting parts. I've just found the hard way that these often result in shorter compressor life.
Okay, I don't plan on doing any system work( freon). Just , fan motors, defrost,  themostats ,relays.
Are you referring to the " hard start kit" 3-n-1?I thought of purchasing a 3-n-1 for testing compressors which might lead to condemning the appliance. Again, no system work for me.
I'm not talking about doing sealed system work, either. But the fact is that using the wrong starting components on a compressor will result in shorter compressor life. And yes, 3-in-1s are bad to use, also. I think any of the generic starting components that go on a compressor are not good to use. I've just seen that they caused shorter compressor life. Take it for what it's worth, compadre.
Yes indeed, no generic parts on the compressor, if I want to keep friends.
I will look to FSP.
Thank You
I will look to FSP.
Thank You
FSP are "Whirlpool" parts. An "Ole Fart" like me used a 3-n-1 with a line cord attached to test a compressor when time was not on my side, but used manufacture parts once unit was working.
