Tuco Posted November 16, 2010 Share Posted November 16, 2010 Thanks Link to comment Share on other sites More sharing options...
Tuco Posted November 16, 2010 Author Share Posted November 16, 2010 I am looking at the Samurai repair manuels stash.I believe this Kenmore is a Frigedair/eletrolux? Am I on the right path?Thanks Link to comment Share on other sites More sharing options...
RegUS_PatOff Posted November 16, 2010 Share Posted November 16, 2010 Frigidaire Kenmore 253.59482990 Who Makes Sears KenmoreWho Makes Whatno info at Frigidaire for that exact modelwhat area has the problem ?parts list & diagrams at SearsPartsDirect Link to comment Share on other sites More sharing options...
Tuco Posted November 17, 2010 Author Share Posted November 17, 2010 Thanks Reg. I needed to know were the defrost clock was on this frig.The Sears diagram showed the location. I am going to work a defrost problem for a friend.Thanks! Link to comment Share on other sites More sharing options...
BrntToast Posted November 17, 2010 Share Posted November 17, 2010 check DTS first, the friggy fridges have bad DTS, you will usually find the top is actually popping off the bad onesthe good thing about most friggy fridges is the dts wires unplug in such a way that you can plug the harness togeather to bypass the dts to quickly test the rest of the defrost system with the dts bypassed Link to comment Share on other sites More sharing options...
Tuco Posted November 17, 2010 Author Share Posted November 17, 2010 Thanks Toast. I'm still an apprentice, forgive me , whats DTS. Link to comment Share on other sites More sharing options...
BrntToast Posted November 18, 2010 Share Posted November 18, 2010 Defrost Termination Switchdefrost therostat Link to comment Share on other sites More sharing options...
Tuco Posted November 18, 2010 Author Share Posted November 18, 2010 [user=20728]BrntToast[/user] wrote: Defrost Termination Switchdefrost therostat Got it now, thanks! Link to comment Share on other sites More sharing options...
Tuco Posted November 18, 2010 Author Share Posted November 18, 2010 [user=20728]BrntToast[/user] wrote: check DTS first, the friggy fridges have bad DTS, you will usually find the top is actually popping off the bad ones the good thing about most friggy fridges is the dts wires unplug in such a way that you can plug the harness togeather to bypass the dts to quickly test the rest of the defrost system with the dts bypassed Wow! I'll do this and put the heater in seris to see if heat comes on. And I'll make sure the defrost clock is on too. Thanks Link to comment Share on other sites More sharing options...
