Water from the dryer?
AmTec Services
Just spoke with a cust I replaced a dryer belt for yesterday. She said she has water from the dryer vent! Any thoughts where this is from and the solution? The dryer was full of lint, but I cleaned it up and replaced the broken belt. HELP!:shock:
..................AmTec :D
  • Replies 8
Vent full of lint and making water... these are classic signs of a bad vent. Could be too long, constructed of wrong materials, too many turns or bends, etc. Some background info on dryer vents==> http://fixitnow.com/wp/2009/06/11/dryer-venting-requirements/
The water is probably coming from the vapor condensing inside the vent.
That's a pretty common complaint in these parts this time of year, as the High today reached minus 19 degrees C today in the sun, shovelmainia the last week with about 2 feet of the Whitestuff in storage all around. Sump'n tells me that isn't as apt to happen in your climate without some serious ventage issues.
I should mention that winter isn't all bad as on the flipside, it makes a great help for storing freezer food when repairing fridges !
Had my share of that when I lived in Michigan! I'll take the heat anytime!:D
ya, but always remember if you suggest storing the food outside, use a cooler or rubbermaid, i've had several customers rant that neighbors pets got their food that was in cardboard boxes
and ya, i get several complaints of leaking dryers a year too, pulled a vent one time and got a boot full of water  :(
That's the Dryer workin in reverse, making your clothes wet
[user=66622]AmTec Services[/user] wrote:
 She said she has water from the dryer vent!  :D
  • 2 weeks later...
i've had it 2 times. both times the dryer was vented into crawl space. the wter heater pop-off had blown drectly behind the wall and was vented into the crawl space. steam was condensing in the dryer.. also new steam dryers will leak...
Good info on the steam dryers! :D
