Gold Medal 2388 8 oz
Matt_In_Michigan
Matt_In_Michigan
Let me preface this with, this is a popcorn machine given to my wife's special education class.  It's a $600 machine, that needed a new element for $35.
According to the schematic, my wires are hooked up correctly.  However, once it reaches a certain temperature, it trips my GFI in my workshop.  It doesn't trip my breaker, but the GFI.  The thermostat in this thing is very rudimentary.  It's basically a cover with 2 screws on top, and inside are two pieces of metal.  1 is V shaped and attached on both sides, and the other is just a flat piece attached on one end.  I have a feeling the thermostat is bad, but have no idea if I can test it before I order a new thermostat.
Any thoughts or suggestions?
Thanks in advance,
Matt
It may be just a finicky GFI.
Try it in an Outlet that has a different brand of GFI.
It may be that the oil/salt/fumes got into the Thermostat, causing leakage to chassis ground.
click on picture
click on picture
 my video production: “Easter Seals Walk With Me”
I would try another gfi, or a non-gfi outlet and see what happens. some appliances don't work well with gfi's.
I would say MOST.
