Guest Bobo385
ken frig 795.77243602 Fresh food section the lights are possessed will stay on with the doors closed burnt the top a bit then will not come on at all this go on back and forth. Light switches are good. Think its about the time out sensor. Not sure who made it for ken wondering why they would do this to the lights.
  • Replies 5
  • BrntToast
  • RegUS_PatOff
made by LG
i havn't been able to find the wiring diagram, if you can take a picture of yours on the back of the fridge and post it up
i suspect the lights are switched,and then controled by a relay on a board, this relay is probably stuck closed
some fridges have a thermostat located near the lights to prevent overheating,and this would explain why the lights go out and not work for a while, the therm trips and then has to cool before it resets
without that wiring diagram i am thinking you need the good ole LG fridge control board
i hope you have removed the light bulbs to prevent further damage
Edited by BrntToast
Kenmore 795.77243602 made by LG
similar to LRFD22850ST
quote from post of a different LG model:
This repair is **usually** done by LG for free.
Call LG Customer Service: 1-800-342-0000
Parts needed:
1) Main Board
2) Lens Cover
3) Reflector
4) Case / Housing
5) Sockets
6) Overlay
The new MAIN BOARD has a much larger lightbulb-relay---which reduces the possibility of a repeat.
In addition--the SOCKET ASSY has a THERMOSTAT wired-in. This shuts off the light bulbs if the temperature of the lightbulbs & the housing becomes too hot.
once again master Reg comes through
whatever the samurai pays you, he should double it
we both know the humor in that statement
Guest Bobo385
Yep took the light bulbs out. Did not see wiring diagram on the back couldn't find a tech sheet either unit looked like someone worked on it before me. can u send me the lrfd22850st manual. your manuals are like gold cant get enough of them
Guest Bobo385
forget the manual.Already have it from your site just found it. Thank you
