Anybody have a tech sheet/wiring diagram for a model like this. It's a gas range with spark-ignition oven. Got sheet #9761386 off scribd. Close enough? Thanks in advance!
  • RegUS_PatOff
  • vee8power
Tech sheet should be cleverly hidden in the range: pots drawer cavity, back of range, poke around, you'll find it.
Here's some troubleshooting help on the gas valve:
Whirlpool DSI Gas Range GS563LXS - Bake and Broil Solenoid Activated Ports
Troubleshooting Tips:
Both coils on the gas valve have to have continuity or it will not work. The DSI control checks this before it does a function. Also these coils are LOW VOLTAGE DC 8 to 18 VDC.
If you have 120v coming out of the ERC & in to the new DSI board at Bake J1-6 or Broil J1-7 then you know the ERC is calling for heat properly.
At the gas valve, remove the wires and ohm from the center terminal (Common) to the upper one (Broil); then from the center terminal (Common) to the lower one (Bake). If either one is open then you need a gas valve==> http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/1159151?modelNumber=GS563LXSQ0
