If these are the same as the "Asko Type TD 73 Dryer Service Manual Request" thread answered yesterday, then don't worry, I got those already. If they are different, please send 'em my way.
The TD77 has no model name or number on the front, perhaps it was before the time of model numbers? The TD77A says 7705. They appear to be very similar, except the TD77A has a slightly different control panel with LCD display, whereas the td77 has a two character LED display. As one might guess, i believe the td77 is older, the td77a/7705 is newer.
They are both, as my situation requires, condensing driers.
tia
b
  • Replies 1
  • RegUS_PatOff
  • squib308
...TD77A has a slightly different control panel with LCD display, whereas the td77 has a two character LED display.
"TD 77A is a condensing tumble dryer, which incorporate a microprocessor for process control, with pushbutton selection of programs.
The pushbutton panel also carries LEDs and two-digit 7-segments displays which indicate selected time (for times programs), time-delayed starts etc."
u77ind.pdf
