GE dishwasher PDW8680N00SS
AmTec Services
Took a quick look at this unit the other day. The drain pump runs, but not a drop of water from the drain.Looks like I can get the pump out without uninstalling the unit. Possible?
Any other thing I can look for? Whats the best way to remove the fine screen and sump?
...........Thanks guys!
.........................AmTec :thanks:
I PMed you the service manual.
With the drain hose off the pump, pucker up and blow like a fish to make sure the hose is clear. Should be a slug of water and blow clear after that.
Humble thanks o great one!!
................AmTec :thumbsup:
Went back to repair this unit. Just like the manual said, had to pull it out to service it. Blew thru the line like the Master said and it was clear. R&R the pump and reinstall. Works like a champ!
What caused the pump to fail? I'll take the old one apart and look inside. :wallbash:
Humble thanks to the Master! :thumbsup:
