Kenmore 596.75524400
AmTec Services
This is my sister in laws refig. Found the compressor hot and off on thermal. Checked windings and found no opens. Installed 3 in one to try and start it. Locked up. Ordered new comp and installed it this afternoon. Got ready to fire it up and found the control board in side is acting up. Sometimes it has a display, some times not. If you push the light switch the display goes out and wont come back on. Cant do a diagnostic if the board wont light!
When I checked it before the comp install, I noted the numbers on the control would sometimes flicker. The wiring diagram shows this to be the primary control. Do I need to get a new board? HELP!!!!! :excl:
.............AmTec
  • Replies 10
looks like it ..
12002339
Substitution:12868513
click on picture
Programming Instructions
Thanks Reg!!! :thanks:
..............AmTec
Could have cooked the control by wiring one of those in there
I was wondering that also. But how? :wallbash:
................AmTec
Installed the JAZZ board and all is well. You can get a serious backache changing that puppy out! The board had a burn mark on it. My question, can a 3 in 1 burn this board, and if so how? I will not hard wire another one into the control circuit for a test. Wire on my cheater cord first. The master says they are dishonerable and evil. From now on if it wont start with the correct relay, they get a new comp. :whistling:
...............AmTec :thanks:
When I worked for Maytag Factory Services we used to run out of these compressors every summer around July. These Techumseh compressors, (identifyable by a blue Indian logo) had about a 70 percent failure rate. I know you have a Kenmore refrigerator, but Amana made this refrigerator for Sears. This same refrigerator was also sold under the Amana and Maytag nameplates.
Yet, I have the EXACT same compressor in my Amana bottom mount that has run flawlessly for almost 15 years - it's kida like dice - the key is to keep the condenser clean. Mine actually "warns" me that cleaning is required by starting to freeze vegetables in the crispers. After a good cleaning, the run time must reduce and this effect disappears
I have been told more than once that a 3 in 1 can cause electronic control damage, but never cut them into the circuit anyhow. I will use one wired to a cheater and power the compressor to test, but isolated from the cabinet wiring.
Thanks guys. Thats why I'm here. Need to learn as much as I can!
................ :thanks:
.........................AmTec
  • 7 months later...
richseattle56
The newer refrigerators that have a board, of any kind, should not have a 3-in-one hooked up to them. Sensei, what your saying is you can hook them to the compressor and then use a 120V cord to power them? Let me know because I won't even try them if fridge has a board.
Yes - only to isolate and test run the compressor - NOT wired into the fridge control circuit
