    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
rheem gas furnance
hawgwildtours
MY FRIEND HAS A RHEEM GAS FURNANCE WITH SPARK IGNITION>HE SAID HIS BURNER WILL LIGHT AND GO FOR ABOUT 5 SECONDS AND SHUT DOWN AND THEN THE BLOWER MOTOR WILL COME ON.ANY IDEAS,,THANKS
  • Replies 7
model number ?
The control probably ain't gettin ignition confirmation. Tell your friend to remove the ignitor sensor and clean it with a dry brillo pad. Reinstall and retry it.
how old is this furnace? it could have a honeywell smart valve ignition control system, which is a bit more complicated.
HE CLEANED THE SENSOR WITH EMERY CLOTH AND ALL IS WELL..THANKS AGAIN FOR THE BEST ADVICE SITE ON THE WEB AND THAT IS SAYING A MOUTH FULL
I agree with applianceman1800. He Throws around that " sand your flame sensor" alot , but in this case he seems to be right. The symptoms do indicate the board was sensing " flame failure" .
STILL WORKING GOOD,,CALLING IT FIXED AND MOVING ON THANKS AGAIN
