Hi there,
Would you be able to send me the service manual for the Fisher & Paykel E522B fridge?
My freezer has been icing up. I watched the service guy remove the freezer side panels last time to access the iced up area at the back, but I can't seem to do it myself.
Just need to know the trick to removing them.
Many thanks
Tim
Oops - that's definitely 522B not 552B
Edited by Timmo
  • Timmo
  • RegUS_PatOff
517800 Fisher and Paykel 790-active-smart-ref-svc
link PM'd
Thanks for the manual, much appreciated.
Unfortunately I couldn't see from that precisely how to remove the internal freezer evaporator covers - though I saw mention of using a small flat-bladed screwdriver somewhere.
I ended up just defrosting it for a few hours instead, and will check in the morning to see if it has gone back to normal operating temperature.
I may also try (very gently) removing the panels using a screwdriver underneath, just so I can do it for next time.
It has been a frustrating (but hopefully successful) day with appliances - I had the washing machine malfunction too, but dismantled it to find a small plastic tab from a shirt collar lodged in the inlet/recycle solenoid. Again, I'll check that it runs OK tomorrow.
