ge m#GSH22JFXAWW
cuzzin sam
Hi folks, this side by side has no water in the door. I have good pressure thru the filter etc, all the way to the coupling below where it goes up into the door. I was gonna take the inside panel off of the door to see if the line is frozen, kinked or...and found no screws holding the gasket on or the panel in. How does this door come apart? Or even better, how can I get it apart AND back together? Thanks, yall, Sam
  • Replies 4
the door is sealed, you cannot access it...i believe there is a heater kit available for it now. i will try and find the part #
and as I patiently wait, you know I'm gonna be wondering how am I gonna get a heater inside the sealed door...Sam
Hey Sam;
I used the heater kit on a sxs with the same problem. Worked great and easy to install. Just dont drop the dispenser circut board like I did! :wallbash:
.....................AmTec
