customer self-cleaned both ovens at same time. Board burned out, replaced it and tested locking mechanisms, door and micro switches, fuses and oven sensor. They all appear and test okay. Tested continuity on about a zillion wires. Bottom oven door will not unlock. Maybe there is some hidden clue in the manual. Thanks again!
  • Replies 1
  • RegUS_PatOff
  • DurhamAppliance
“My Rules”:
Rule #1) Don't ever use Self-Clean on any Oven.
Rule #2) If you're thinking about using Self-Clean, see rule #1.
That can wreak havoc on Electronic Controllers and Connections.
31-9084 27 in BI Wall Oven.pdf
