Greetings from BC!
I was hoping someone may have available a service manual for a Maytag MAH2400AW compact stacking washer. My brother-in-law just got one that isn't working, so as always I got the call.
Any help is appreciated!
Thank you in advance,
Regards,
Stuart
Edited by Mechanic
  • RegUS_PatOff
  • Mechanic
Maytag MAG2400AW
can you check that model number again ?
Sorry Sensei,
I had it correct in the subject line MAH2400AW, though there may be an extra W at the end depending on the source (MAH2400AWW), Maytag Canada lists it as MAH2400AW, while on the machine it is MAH2400AWW.
Stuart
here's the tech sheet
16027174.pdf
