Bosch 300 series dryer, Model # WTVC3300US/10 (FD9004) 302269
I’d like to learn how to remove the bottom front panel so I can easily clean the bottom of the lint screen port and exhaust duct. The problem is that the bottom of the duct collects debris/lint that the screen doesn’t catch. There is a sensor located in this area that needs to be cleaned occasionally and although accessible, it gets coated with lint and erroneously alarms and even shuts down the dryer down as a fire safety feature.
  • Replies 9
  • burnsb
    4
  • RegUS_PatOff
  • cagaines
Ah, the Bosch "Vision" dryer. I PMed you the download link to the manual. The overall procedure is on pg 22 but it calls procedures from previous pages. Pretty easy to sing along. :whistling:
  • 1 year later...
I have a WTVC3300US/10 that is not heating. I've visually inspecting the outlook and plug and I've reset the breaker, but I haven't tested the outlet. I've vacuumed out the dryer vent and the duct (they were pretty bad). Dryer is still not heating. I was planning on replacing the heating element, but I can't figure out how.
... I haven't tested the outlet.
why not ?
should test for 120v & 240v at the Dryer Cord terminal Strip
Ok, the terminal strip has a black wire terminal, a white wire terminal, and a terminal with a red wire and a brown wire. The voltages are:
Black to White: 116 VAC
Black to Red/Brown: 233 VAC
White to Red/Brown: 117 VAC
Is it safe to assume that those are close enough to spec?
yes
I took the top of the dryer, but the heating element is not visible from the top. Can someone provide instructions? Thanks!
  • 9 years later...
i'm seeing 500s and 600s but no service guide for the mtvc3300us10
Here's the manual for this one:
