Need service manual for Bosch Washer WFMC544SUC-15. thanks in advance!
  • DurhamAppliance
Closest I can get on that one is the 2nd edition of the WFMC training manual, which includes the 5200 series. May be good enough. Download link PMed.
What problem are you having?
Thanks....small amount of water is leaking from the bottom, looks like it is coming out of one of the bottom plugs. A plug may be defective but I am assuming that water should not be accumulating inside the bottom of the washer for it to leak out. Need to disassemble machine to search for possible leaks. The manual pmed should do the trick. Thanks again!
Edited by DurhamAppliance
