Need disasembly help
AmTec Services
I'll be going on a couple repairs and need some teardown advice.
First is a Microwave #MCO153UB, this unit needs the door handle replaced. How do I open the door assembly. I know it's simple, but I dont want to break it while trying to access the door interior.
Second is a stacked washer dryer combo #FLXE52RBS8. The felts and glides need replaced on dryer. I need advice on opening the dryer cabinet. I cant see how the bottom of the dryer front is attached. Looks like the control panel needs removed. Again, I dont want to break anything pulling this apart!
I await your sage advise!!!
.........AmTec :thanks:
couldn't find the Ewave / Magic Chef M/W
this may help
ftp://ftp.electrolux...er/95350385.pdf
Just replaced the rear tub bearing on one of these. Remove the two screws (#31 in drawing) and remove access panel (#39). Remove two screws in control panel (#18) and rotate down. There are two hidden screws not shown in diagram on lower front of front panel (#22). Then take screws (#2) out of top of front panel (#22). Disconnect door switch.
