i'm looking inforation calibrate this oven
  • Replies 6
  • court
    4
  • RegUS_PatOff
thanks for the reply,but i couldn't down load it
click where it says ""Click here to start download.."
thanks it down loaded this time,but my problem is i set temp at 350,but it only gets to 317 inside oven.on some models you run temp all the up wile still holding the button in until off set flashs.this model doesn't
sorry, wrong manual ...
Calibration:
To check oven calibration:
1. Place a thermometer or thermocouple in the center of the oven.
2. Program the oven for bake and the temperature to 350° F.
Allow the oven to cycle three times.
3. Average the highest and lowest readings.
The average should be within 10° of 350° F.
The calibration of the ES 100 system cannot be adjusted:
1. If the oven temperature calibration is off.
Check the resistance of the oven sensor circuit against the chart below.
If the sensor circuit checks good replace the control.
Degrees F . . . . . .Resistance (Ohms)
32 +/- 1.9 . . . . . . . 1000 +/- 4.0
75 +/- 2.5 . . . . . . . 1091 +/- 5.3
250 +/- 4.4 . . . . . . .453 +/- 8.9
350 +/- 5.4 . . . . . . 1654 +/- 10.8
450 +/- 6.9 . . . . . . 1852 +/- 13.5
550 +/- 8.2 . . . .. . . 2047 +/- 15.8
650 +/- 9.6 . . . . . . .2237 +/- 18.5
900 +/- 13.6 . . . . . .2697 +/- 24.4
thanks that helped
