Maytag washer MAH8700AWW
AmTec Services
I got a call from a lady saying her washer quits in mid cycle and shows code E3. Says she restarts and sometimes finishes sometimes not. Any thougts before I run the call?
.............................AmTec :thanks:
Got some good info on this problem at my blog ratcheer. :thumbsup:
E3 Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Tech Sheet 16026882.pdf
Service Manual 16026126.pdf
:thanks::thanks::thanks:
..............AmTec
