Hi All!
I have a Viking DFSB482 Side by Side Fridge/Freezer [yes one of those units that got recalled by Viking b/c the doors fall off due to poor hinge design] that is running hot. I cleaned all exterior coils & fans [FUN!] and unit is still running hot. The conditioned air from the evap coils in the freezer box is blowing [slowly?] -8 to -10 degrees F; however, the the air in the fridge box never falls below 39F and there is considerable frost build up on the freezer door directly in-front of the evap coils. There is/are no obstructions in front of the upper and lower openings between the R/F boxes. Gaskets replaced about 2 years ago when Viking did hinge recall, they look in fair shape and for the most part pass the $ bill test. Unit was working fine until about a week ago, I then undertook all the above maintenance. All this leads me to believe that one or more of the interior circulation fans are staring to fail or have failed completely & thus the request for the service manual I need to find all the fans to test them & replace as/if needed. I will also need part #'s list to order if needed. Any and all help is sincerely appreciated, as are any other suggestions for a fix if I am missing anything pertainant...which I usually do! THANKS!
  • 2 weeks later...
  • Replies 1
  • 148bth
OK so here is the update. I found the evap fan was shot [this is now the 3rd one put in service], got part # from old repair invoice Viking p/n G5098660 [Evap Fan Assy] replaces G5096492, G5096970, 10654206 & V1065426. So now freezer side runs cold 0 degrees F at least, not sure if it is supposed to get colder [but seeing as all my other freezers go to at least -10F I am pretty certain this one should too]. But here is the problem even at MAX F and MAX R the fridge side wont go below 40F :wallbash: ! Does anyone know how the damper at the bottom of the unit between the freezer and fridge should be set/configured? As stated above the gaskets, for the most part pass the $$ test, is it possible that where they fail slightly be the issue? What am I doing wrong?!? Does anybody have a service/troubleshooting manual/guide for this or a similar unit? I am loathe to call Viking b/c they S*CK! This unit has been nothing but trouble...would never recommend or purchase another Viking unit! EVER!!!
