widowbryant
Maytag LSE7806ACE Stacked washer dryer
Service manual request - thank you ever so much!
rebecca
  • Replies 6
  • widowbryant
    4
  • RegUS_PatOff
All I have on this one is the parts and wiring diagram. Maybe Master Reg has sumpin up his sleeve.
widowbryant
Thanks for the try though. *smiling* I have the parts list. Am looking for the service manual.
Thanks again for caring enough to reply.....
rebecca
what part / problem are you having ?
widowbryant
The washer drum suddenly stopped spinning, but it pumps out. I smell a bit of burned rubber like when my vacuum belt breaks. The unit is older. I haven't pulled it out of its cubbyhole yet, but ordered both drive belts cause I figure it's probably time to replace them. Already did the dryer belt last year. When the washer belts arrive I'll pull the thing out and replace those, but it might be something else. I read about the transmission, or perhaps an old sock stuck between the the tubs, but can't find a diagram on how to remove the top tub ring. I felt around in there but no socks jumped out. I joined this forum because I thought it'd be good to have a service manual for this thing since it's starting to require the occasional repair. I figure it's a foreboding of things to come, so better get a manual.
I'm a girly farmer living in a rural area and pretty good with fixing things. (Good cause there's no washer repair men roundabouts. *grin* Gal gotta do for herself.)
thank you!
rebecca
same Washer Tub / Basket / Transmission as Maytag LAT1000 / LAT2000
16010373 Washer service manual
link PM'd
widowbryant
Thank you for the manual. I'm still trying to narrow down the issue, and have posted in the general washer repair forum.
I appreciate you!
rebecca
