Fault code F 3 H. Humidity sensor? or ....? thanx in advance
  • LLAMBERT
Yep, F3H is the humidity sensor. There's a rigamarole to follow for this fault listed in the tech sheet, which I've PMed you.
domo.. I see the rigamarole, they left out the part about putting your whole head in, and taking your whole head out....
... they left out the part about putting your whole head in...
... with the microwave on. :dude:
For others coming along later reading this, the F3H rigamarole:
1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P3).
3. Plug in microwave oven or reconnect power.
4. If problem persists:
■ Unplug microwave oven or disconnect power.
■ Replace power supply board.
5. Plug in microwave oven or reconnect power.
