Compressor overload and relay
chance85
Which overload/relay kit do you keep on hand. The one I'm using now is a bit pricey.
  • Replies 6
which part number are you using now ?
I think all look-alike PTC Starters are all the same,
but the Overloads are rated by amperage ...
Have been using a couple different ones. Looking for something like the W10247581 rework kit that covers a wide range of compressors.
I learned the hard way to only use OEM start relays and components. I don't mess around with the Supco 3-in-1's anymore. But I'm just nutty thata way. wacko.gif
I am on board with the Grand Master :yes: on O.E.M. parts...If any thing goes wrong down the road and you used the correct O.E.M. parts, you do not need to second guess your self, "What If " :wallbash:........... In my neck of the woods, I carry the W/P kit 8201786.....I have done two different units off of one kit ( left over parts in the kit ) :rolleyes:... I beg to differ on the 3-N-1 hard start..For the dying or with the windings in the yellow ( on the Meg-O-meter )..... I carry the Supco RCO 810 ( service call/parts/labor- $155.00 )....It will get them thru till they can acquire another refer.
I agree with everything CTG51 says. Another good kit to have on hand is also the 8201799, (it only comes with one ptc push-on relay and two overloads that will take care of most all 20-27 Cb.Ft. SxS.
The kit CTG51 mentions above has many more parts in it and as he says you can do more than one job with that kit. You get one ptc push-on relay and two overloads and then you also receive two complete relay/overload push-on paks that have the post to mount a run capacitor - the overloads in the two complete paks are the same as the two individual overloads.
The complete relay/overload paks have a special plug in connector with the two small 1/8" spades side by side so you either have to have a spare connector of that special type or a couple the small insulated 1/8" push-on spade connectors like come with the Whirlpool dryer motors.
some info:
KILXON
PTCs
2188829 black dot
2188830 red dor
OVERLOADs
1118841 819198
2154697 437NFBYY for EGY90
2154758
2154759 4387913
2154760 319RFBYY
2154761 4388953
2154945
2183409
2183452 4387938
2187145 445KFBYY for EGY80
2214067
2319792
4344040
4356717
4387535
61006294 2162218 427NFBYY for EGU70
61006296 445NFBYY for EGY100 EGZ100
936073 819098
http://www.klixon.com/download/4tm.pdf
