GE washer WJSR2070B2WW
AmTec Services
Hey all;
I've got a GE washer that will fill and agitate well. Pumps out good but will not spin. I checked voltage at motor on spin and have 73 volts with wires off, 0 volts with wires attached. Looks like the timer, but want to be sure. Any advice for this humble student?
............... :thanks: Amtec
Edit: Lid switch checks good! :thumbsup:
  • Replies 9
Do you have a wiring diagram for that model that you could scan & upload somewhere ?
If it's easier, can fax it to me at 866-315-4504 and I'll post it here as a PDF. Please note your topic on the fax somewhere so I know what the fax is for.
My humble thanks Samurai!!!
.............. :thanks: AmTec
Did you recieve the fax? :whistling:
...........AmTec :thumbsup:
not much else it could be...
click on picture
.................. :thanks:
...........................AmTec
Timer installed, she be a spinnin!
..................Thanks to Reg and the Samurai!!!
.................................AmTec :thanks:
