Hi All, Does anyone have the service manual for GE Range Model# JRS04BW2BB? Thank You Very Much, Bob
  • Replies 4
  • Adirondack Bob
  • RegUS_PatOff
I found out that the tech sheet is 31-13319. Does anyone have that. Thank you very much, Bob
what area are you having a problem with ?
F4. Tested temperature probe and got 1100 ohms at room temperature.
I'm not getting anything for that one. Is the tech sheet missing? It'll either be in an envelope taped to the back of the range or in the pots drawer cavity. If it's missing, you can get a replacement from GE at the customer's expense.
