I need the manual for this product; I need to perform a little maintenance.
  • RedToryTy
  • RegUS_PatOff
I can't find anything for that c.1987 Range
maybe only parts diagram
Sensei Reg,
The front left surface eye of this product heats 100 degrees higher than its original, circa 1987 counterpart. I've changed the block and switch of the offending eye; what should I do to get equal heating for both large eyes? I'm planning on replacing the 1987 block and switch.
Sensei Reg,
I just learned from this customer that the left, front eye was overheating BEFORE any parts were changed, and continues to overheat after changing terminal block and switch. Might the surface element's ohm resistance degraded, allowing this one unit to overheat. Please; any help is greatly appreciated.
