G.E. refer...DSS25KSTBSS
ge..DSS25KSTBSS....'ADORA'.... Need a service manual for this unit.......refer freezing food in the bottom of the fresh food section......3 volts D.C out of the mutha board for the evap motor..( should be 12 volts )........I do not see to many G.E.'s <_< .....( thank God )....... SO, I think I will apply 'rule of thumb' and get a new board and a new evap. motor.... "Can I get a hurrump out there?" :thumbsup:
  • Replies 5
  • certified tech group 51
Sent you the tech sheet. Will look around some more for the manual.
..... :thanks: ..... Thanks for the two pages........I used a G.E. Arctica for a guide...could not find the tech sheet on the unit....Found only 3 volts D.C. :blink: ......... somewhere I had read to replace the main board and the evap. fan motor at the same time...... Bummer, too cold at the bottom of the F.F. side, froze and cracked the water chiller... <_< ... more money after bad..
Sent you a couple more goodies on AC and DC testing procedures for the muthaboard. dude.gif
Now those are tech. sheets. :thumbsup: ...cannot get any more simpler then this.... :thanks: ..makes me want to do more G.E. refers :woot: NOT...
